Old Magic Chef Stove won't Light
Old 11-03-07, 03:23 PM
A
Question Old Magic Chef Stove won't Light
We have a 15+ year old countertop Magic Chef Stovetop. We just turned the knob and we smell gas but nothing is lit. I am guessing its just the pilot light but not sure how it went out- can we just turn on the gas and light it with a long match? Thanks!!
Old 11-03-07, 05:16 PM
D
Did the burners it spark lite before? If yes and now none will light, you might have a bad spark module [about $36]. Can you post the model #? You could try to match lite but be careful.
Old 11-04-07, 06:30 AM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Hello Allison1ga. Welcome to the Gas Appliances topic and the Do-It-Yourself Web Site.
A 15 year old stove top not likely to have constant burning pilot lights. The stove top cook appliance is more likely to have a spark ignition. Usually one sparker for each burner but some models use one sparker for two burners.
If you heard sparking prior, then the appliance has spark ignition. If that is correct, then the spark module is likely burned out, as mentioned by daddyjohn.
Be sure to check for electrical power to the appliance at the wall receptacle before replacing any part.(s) Use a known good working table lamp, if you do not have an electrical tester. Plug the lamp into the electrical outlet. If the lamp lights, there is power. If not no power. Determine why and repair or have outlet repaired by a professional.
If and or when you attempt any repairs, "Be sure the electrical power to the appliance is turned off or the stove top is unplugged from the power source before attempting any repairs."
Until the spark module is replaced or the wall outlet is repaired, you can light the burner(s) with a match.
Kindly use the reply button to post all replies, add additional information or ask additional questions when replies are posted. Using this method moves and/or keeps the topic back up to the top of the list of questions automatically and keeps all content on the same subject within one thread.
Web Site Host, Gas Appliances Topic Moderator & Multiple Forums Moderator. Energy Conservation Consultant & Natural Gas Appliance Diagnostics and Repair Technician.
Personal Driving Safety Reminder:
Buckle Up & Drive Safely. "The Life You Save, May Be Your Own."
