GE Gas Range oven doesn't work
Old 12-20-07, 09:38 PM
Angry GE Gas Range oven doesn't work
My brother has a GE Range and wanted me to see if I could get some information as what the problem may be.The serial #GM205725P/ model #JGBP26GEV2WH.
The surface burners are fine, It's only the oven.
We feel it is the igniter.
Any suggestions?
Old 12-21-07, 06:54 AM
Sharp Advice's Avatar
Admin Emeritus
Received 5 Votes on 4 Posts
Hello verner34. Welcome to the Gas Appliances topic.
Everyone would be very pleased to help you. But first you need to help us. We need much more detailed and specific information. There could be any number of potential problems.
Detailed information about the problem or problems with the appliance helps to explain the situation your dealing with in a manner that allows the professionals to offer the best possible helpful suggestions and advice.
Any and all additional detailed information you can provide may help to expose a clue regarding the current problem and help us to determine the exact solution to the problem.
Your assistance in this matter would be beneficial.
Read The Sticky Help Note In This Topic:
Range-Stove-Oven-Broiler Basic Help Information & Manufacturers Web Sites. http://forum.doityourself.com/showthread.php?t=159808
Help us help you. Add more details and specific information, please use the REPLY button.
Old 12-21-07, 03:12 PM
GE Gas Range oven doesn't work!
Hey guys I'm Willing to give you all the information you want.
This range works fine except for the oven, I don't know what else to say, the oven will not heat up. The broiler works fine.
All the top eyes works fine. If he could get the oven to work,
he would be in business.
This is a GE range serial #GM205725P-- model #JGBP26GEV2WH.
As I mentioned, we thought it might be the oven igniter but wanted to get your view as it is a non-returnable item.
If there is additional information you need, I would be happy
to give it to you, the only thing i'm sure of, is won't heat up.
I hope this helps some.
Thanks
Old 12-22-07, 07:42 AM
Admin Emeritus
Arrow Replace The Igniter.
Hello: verner34
If all the control selections are set correctly and the glow igniter fails to light, regardless of whether it is returnable or not, you'll need to replace it. Good idea to replace it even if it does glow. They wear out over time and usage and are often the cause of the problem you described.
Replacing the hot surface igniter (HSI) can be considered a first attempt to fix the problem. Not that difficult to do nor that expensive of a part. Considering the cost of any other part(s) which might be defective.
Replacing the hot surface igniter (HSI) is likely to resolve your ovens problem...
Reading some of the other posts in this forum, you'll notice replacing an igniter is one of the first attempts to resolve such problems. Reading the sticky note has a post within it that details the common method(s) for replacing an igniter.
Regards and Good Luck.
Old 12-27-07, 08:58 PM
Smile GE Gas Range oven doesn't work
Oven fixed, Thanks guys, and it was the igniter.
I can smell the biscuits cooking!!!!!
