Gas Range - Soot
Gas Range - Soot
One of the burners on my natural gas range is producing suit.
Does the burner need to adjusted?
The suit is staining the stainless steel range top. Do you know how the stain can be removed? Stainless steel polish doesn't do it.
Thanks.
Thanks.
Received 7 Upvotes
Hello r95753 and Welcome to the Gas Appliances topic.
The burner that is sooting will have yellow flames. Indicates a lack of air being mixed with the gas. You'll need to clean that burner around the air shutter. Air shutter is located on the back end opposite the burner head on the burner tube.
Burner may need to be removed to inspect the inside of the tube. May have an air restriction inside the tube or only on the shutter. Inspect all areas for obstructions, debris, etc. May not need an air shutter adjustment.
More Info Here:
Read the Range-Stove-Oven-Broiler Basic Help Informational Sticky Note, in this forums topic, for more detailed information.
Range-Stove-Oven-Broiler Basic Help Information, Fault Codes & Mfg's Web Site Links http://forum.doityourself.com/showthread.php?t=159808
***If and or when you attempt any repairs, "Be sure the electrical power to the appliance is turned off, before attempting any repairs. Always check for gas leaks whenever the appliance is moved and/or a repair includes any connection of a gas part."
Kindly use the reply button to post all replies, add additional information or ask additional questions when replies are posted. Using this method moves and/or keeps the topic back up to the top of the list of questions automatically and keeps all content on the same subject within one thread.
Web Site Host, Gas Appliances Topic Moderator & Multiple Forums Moderator. Energy Conservation Consultant & Natural Gas Appliance Diagnostics and Repair Technician.
Personal Driving Safety Reminder:
Buckle Up & Drive Safely. "The Life You Save, May Be Your Own."
More Info Here:
