1966 Caloric Compacto 30
We have a 1966 Caloric Compacto 30 range. The upper oven does not keep correct temperatures. I assume that the thermostat is faulty. How do I find the model of the stove and type of thermostat ?
Received 7 Upvotes
Hello madriverskier. Welcome to Gas Appliances topic and our Do-It-Yourself Web Site.
The model number can be located just about anywhere. Not exactly sure where nor familiar with the model. Look for the model number plate behind the stove or inside the oven/broiler. May be in the bottom below the broiler plate or on the door frame or under the top lid, etc.
If your gas utility company offers a thermostat calibration, the thermostat may just need to be re-calibrated.Which is not a do it yourself task. Must be done by a professional.
Thermostat type by brand name may be visible once the temp knob is removed and the chrome trim ring is removed. Model number not likely visible until thermostat is removed.
Check with a local appliances parts store in your area. Bring at least the brand name with you. Caloric brand now made by Maytag. Refer to info below.
Maytag Appliance Home Page:
http://www.maytag.com
Maytag 1-800-688-9900 USA
Maytag 1-800-688-2002 Canada
Maytag is also the maker of Amana, Jenn-Air, Magic Chef and Caloric Appliances.
Repair Manuals:
http://www.Appliance-Repair.org
Retail parts dealers and appliances parts stores can also help determine what the possible problem may be based upon that specific brand and model. Bring the make, model and serial numbers if possible. Dealers and appliances parts stores are listed in the phone book.
Additional Suggestions:
Read the manufacturers on line web site for product information, problem possibilities, causes, solving methods, part locations, disassembly, reassembly methods, repair procedures, pictorials, schematics, repair and or owners manuals which may be available on line.
Cautionary Reminder Note:
Before attempting any repairs, be sure to unplug the appliance from the wall receptacle power source first.
Repair Manuals:
