Magic Chef Gas Oven - turning oven on also sparks burners
I have a 14 year old Magic Chef gas range with the modern iginition
system.
When I attempt to turn the oven on, the top burners always spark and
sometimes they even turn on. Any ideas what may be wrong? The oven
turns on...
This doesn't seem seem correct that the top burners spark when the
oven is turned on...
Any help would be appreciated.
system.
turns on...
I apologize for no one responding to your post until now.
The symptoms you describe don't make too much sense. Is your oven controlled by an electronic control pad on the back splash part of the range or is it a knob in the middle of the knobs for the top burners?
I've heard of the top burners sparking when using the oven but never igniting as the top burners have manual control valves and the oven has an electronic control valve. If you could post the model number on the range I might be able to better lead you in the right direction. The model number should be on a label on the side of the lower draw/broiler panel when you open it.
