dryer shuts off
dryer shuts off
dryer shuts off befor close are dry. i will set the timer for
50 minutes and It will go off in about 15 minutes and the
timer will be in the off position. I cleaned out the vents,
I do this once a month. what could be the problem?
By what you're describing you have a bad timer.
No other malfunctions will cause the timer to advance. Clogged duct, failed ignition.. etc.. will only cause the dryer not to heat properly. It would still run it's course of the cycle.
