Maytag Dryer DG7600 Belt size?
I've got a Maytag Dryer model DG7600, and the belt went missing, what size belt do I need and how do I replace it without taking the whole dryer apart?
Thank you
Thank you
Unplug dryer The dryer must come apart to replace belt. not real hard just watch how it comes apart and put back the same way. Take front off and than lint tube than front bearing panel. Drum should be able to lift out now. I always install belt from front but I think there is a panel in back to thread belt in idler and motor drive. With drum out look at how belt is threaded as you can't see it to well after drum is in.
Take model # to parts store and they will be able to get you a belt
