Gas Stove- Whirlpool - How to get the top off?
Old 06-10-08, 09:18 AM
R
I have a gas stove by Whirlpool. One of the knobs to turn the burner on will not turn. Believe the valve has to be replaced. How do I get the top off of the stove to replace the valve?
Old 06-10-08, 04:22 PM
H
If this is a sealed burner range, you will need to remove the burner caps and screws underneath them. You will also need to remove the burner knobs and the face plate behind them. You should then be able to access the valves.
