Dryer doesn't stop
Old 06-24-08, 05:31 AM
T
Dryer doesn't stop
I have a Kenmore dryer M# 97575100 that is about 10 years old. The problem I am having is that the dryer will not stop at the end of the "timed dry" cycle . It will continue on to the "Air Dry- No Heat" cycle. Was thinking it might be the timer. Any suggestions?
Old 06-24-08, 02:47 PM
Received 1,281 Upvotes on 1,219 Posts
Yep, timers do fail. Had mine go out at only two years.
Old 06-24-08, 06:07 PM
W
But check for sensor signals that could cause this, especially if the timer is electronic.
These guys sell troubleshooting/repair books; maybe they can ship you one for your machine.
http://www.triblesapplianceparts.com...ge_ID=1&DID=11
Old 06-26-08, 04:51 PM
Put your dryer on hi temp setting on time dry for 10 minutes.
Come back after 20 minutes. Is dryer still running? Did the timer advance or still on 10 minutes. If still on 10 Minutes see if power is going to timer. If your getting power to the timer but the timer is not advancing it's your timer.
Old 06-26-08, 06:18 PM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
Red face
Also if the timer keeps going past stop it's the timer
