Hardwick gas store won't light
Just purchased a 10 year old (so the lady says) gas stove - cleaned it up, plugged it in, lights work, but no ignition sounds...and the burners and oven does like l come on. I can light the oven by hand through the broiler and can light the burners, but none of them will light automatically like it is supposed to. I do not hear the ignitor no matter what position its turned to. Harwick Model # CKN4642M-GW-640H. Is there a fuse or something that would cause ALL of the ignitors not to function? Help..
Received 7 Upvotes
Hello Zero-bias. Welcome to the Gas Appliances topic and the Do-It-Yourself Web Site.
Kindly clarify the statement above. No Ignition Sounds? ALL Spark igniter's??? All burners use spark ignitors....Or only in the oven/broiler?
...oven does like l come on. ????....
Clarify please. Oven works? Does not work???.....
If the oven has an igniter, any type, spark or glow igniter, burner should not be able to be lite by hand....hand meaning manually by a match flame.
The safety device in the gas control valve should remain closed and not allow gas to flow to the burner when an automatic spark or glow igniter is used, as the source of ignition, and such ignition source is not working or functioning properly.
Kindly clarify all of the above.
Additional Help Here:
Read the Range-Stove-Oven-Broiler Basic Help Informational Sticky Note, in this forums topic, for more detailed information.
Range-Stove-Oven-Broiler Basic Help Information, Fault Codes & Mfg's Web Site Links http://forum.doityourself.com/showthread.php?t=159808
Kindly use the reply button to post all replies, add additional information or ask additional questions when replies are posted. Using this method moves and/or keeps the topic back up to the top of the list of questions automatically and keeps all content on the same subject within one thread.
Web Site Host, Gas Appliances Topic Moderator & Multiple Forums Moderator. Energy Conservation Consultant & Natural Gas Appliance Diagnostics and Repair Technician.
Personal Driving Safety Reminder:
Buckle Up & Drive Safely. "The Life You Save, May Be Your Own."
"I can light the oven by hand through the broiler and can light the burners, but none of them will light automatically like it is supposed to."
