Charmglow NG grill won't light when cold
Old 08-20-08, 10:00 AM
I have an old Charmglow HEJ-1T grill that will only light when set on Hi right if it is cold. Once I light it the flames are low until it warms up then the flames get to normal size and I can turn it to both right and left sides of the burner. The burner, venturi tubes and orifices are clean. I checked for leaks arount the valve and regulator and other connections and there are no leaks that I could see. What could be the problem?
Thanks,
Mike
Old 08-22-08, 06:50 AM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
More Detailed & Specific Info Requested
Hello Mike. Welcome to the Gas Appliances topic.
Is the grill a free standing grill? Meaning a grill all of it's own?
Or is it part of an oven/broiler cooking stove?
Indoor or outdoor grill?
What type of grill?
BBQ grill or flat iron grill like those used to make pan cakes?
Natural or propane fuel?
Help us help you. Most likely your question remained unanswered for so long is due to a lack of info.
Provide more details, description and photo if possible. Use the reply button to add the above requested info. Thanks.
