GE (Gas Dryer) Not Working! (Titled Edited)
I have a GE DBVH512 that will not work! When I turn the gas dryer on the green display goes on. Then I make my dryer setting and then press start the dryer then counts down then it does the damp sensing and counts down again and then it says CD cool down on the display I unplugged the gas dryer and then plugged it in to try to reset it but it does not work. Please Help!
here is a link to your machine
http://www.searspartsdirect.com/part...F0WW&pop=flush
under the consul should be a tech and will give you a start to fix. several different things could cause this if a tech sheet there it will help with diagnostic.
