dryer stops heating
Received 0 Votes
dryer stops heating
whirlpool dryer model #lgr4634jq0 , dryer starts to heat up i can see flame through heat tube then after about a minute flame goes out, iam sure its a sensor just not sure which one
Sounds lioke you have a gas coil going bad. They work to start than heat uo and open than no fire. here is a link to your machine
http://www.searspartsdirect.com/part...4jq0&pop=flush
look under burner and 13 &14 are the coils, I always replace both coils.
Received 5 Votes
Hello stic and Welcome into the Gas Appliances topic.
Another possible cause is a restricted or clogged exhaust venting system. Which may be full of lint inside the machine at the blower fan cage.
Yet another possible cause is the internal tubing or external venting metal or flex tubing or the hoods flapper vent is not opening fully or opening at all...
Two other possible causes may be either the solenoids on top of the gas control valve or the radiant flame sensor on the burner flame hood.
Ohm test the flame sensor with electrical power to dryer turned off or machine unplugged. Ohm meter should show a closed circuit. (Needle swings all the way over to right side of meter.) If circuit closed, sensor is okay.
Solenoids on top of gas valve may be defective. There are two. Any one of them fails both get replaced. Sold and installed in pairs only. Remove them from the top of the gas valve by removing the entire gas valve assembly first.
To accomplish this task, the entire burner and gas valve must be removed. Then the solenoid coils can be removed from the top of the gas valve and replaced.
The gas inlet pipe to the right side of the gas valve has a tiny on/off gas shutoff valve. Turn it off, lever opposite it's current on position. The nut on the gas supply pipe near the gas valve is counter threaded, which means it turns opposite the norm to loosen it.
There will be other sheet metal screws securing the gas valve and burner assembly to the dryers base. Once the entire gas valve is removed, take it and the make, model and serial numbers of the appliance to the local appliance retail parts store.
Remove both solenoids off the gas valve body by removing the hold down cover plate and replace them both if defective. They are sold only in pairs.
Or take the entire gas valve unit to your local appliance parts store and have the entire assembly and all the parts tested individually and as an assembly.
Once at the store, the salesperson can be sure the replacement parts are the correct ones. Replacing the solenoids is simple and the parts come with full instructions enclosed in the packages.
Defective Gas Valve could be the problem. Remove entire unit as an assembly. Take the entire assembly to your local appliance parts store for testing. Gas valves are not repairable.
CAUTION: Do Not attempt to repair the gas valve. This is a non repairable item. Replacement is the only option, if defective.
Gas Dryer Help Link with all the info needed is here:
http://forum.doityourself.com/showt...threadid=159481
Retail appliance parts dealers can also help determine what the most likely possible problem may be. They will need the make, model and serial numbers. Appliance parts dealers are an excellent source for original replacement parts and problem resolving matters. Dealers are listed in the phone book under appliances.
UNPLUG DRYER FIRST
Take out lint screen and remove 2 screws there. Take a stiff putty knife and slide it between the top and front panel near the side and pry up on each side. Top will pop off clips holding down.(may have to use a little force) lift top up and lean back. look inside at front panel and find 2 screws holding on (near top on sides) pull up on front panel and will come off. Careful of wires to door unplug wires or just put it to the side. Hope this helps, Gas coils are on the lower right side usually
