GE Range Oven XL44 does not ignite or heat up
Old 09-15-08, 09:06 AM
N
The glow iginitor is orange but nothing iginites.
It all started when my son heated some pizza in the oven and fell asleep. The oven then would heat up, but not to any significant cooking temp. Now it does not heat up or ignite. Broiler works and stove top works just the oven. Any ideas?
Apparently the gas is not coming through the valve for some reason...
Is there a reset button? Did the oven shut itself down or it the control valve bad?
Thanks for your help
Old 09-16-08, 05:19 AM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Hello NJREALESTATE and Welcome to the Do It Yourself Web Site and to the Gas Appliances topic.
Very common problem when the HSI (Hot Surface Igniter) becomes to weak to ignite gas. HSI igniter's simply ware out over time.
Replace the glow igniter. Should resolve the problem. Doubt the problem resulted from the over cooked pizza...
Cautionary Reminder Note:
Before attempting any repairs, be sure to unplug the appliance from the wall receptacle power source first.
Read The Sticky Help Note In This Topic:
Range-Stove-Oven-Broiler Basic Help Information & Manufacturers Web Sites. http://forum.doityourself.com/showthread.php?t=159808
Additionally:
Retail appliance parts dealers can also help determine what the possible problem may be. Bring the make, model and serial numbers. Appliance part stores and dealers are listed in the phone book.
Use the reply button to add additional information or questions. Using the reply button keeps or moves the topic back up to the top of the list automatically and keeps all communications on this subject in this thread.
Regards and Good Luck. Web Site Host, Moderator Hiring Agent, Gas Appliances Topic Moderator, Multiple Forums Moderator & Natural Gas Appliance Diagnostics Technician.
Personal Driving Safety Reminder: Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
