1950's Magic Chef gas range
Old 09-30-08, 11:26 AM
Wink 1950's Magic Chef gas range
I have a 1950's Magic Chef gas range model # 33-L P The
flames are very high, I beleive it's supposed to be set up for
propane. The oven orifice is a #56, Front (large) burners are
#68 and the small back burners are #70. Are these the right size orifices? We put the #70 on the oven and the flame looks normal. Where can I get new orifices if needed?
Old 10-12-08, 06:34 AM
Sharp Advice's Avatar
Admin Emeritus
Received 5 Votes on 4 Posts
Question Which Fuel Is Being Used???
Hello Sandra Ann and Welcome to the Do It Yourself Web Site and to the Gas Appliances topic.
Burner flame size depends upon the BTU rating of the burner size. Each burner then can have a different rating.
Usually, top burner flames sizes range between 8,000 to 12,000 Btu's. The orifice is then sized to match the BTU rating for that specific burner. Same applies to each burner.
Without knowing the burners rated size, difficult to say exactly what the orifice size needs to be. However, on the rating plate will be the BTU rating for each size burner. Refer to that for the specific orifice size needed.
Not sure if the appliance is presently using propane or natural gas. Kindly advise which fuel is presently being used and the appliance is set up to use presently.
Retail parts dealers and appliances parts stores can also help determine what the possible problem may be based upon that specific brand and model. Bring the make, model and serial numbers. Dealers and appliances parts stores are listed in the phone book.
Additional Suggestions:
Read the manufacturers on line web site for product information, problem possibilities, causes, solving methods, part locations, disassembly, reassembly methods, repair procedures, pictorials, schematics, repair and or owners manuals which may be available on line.
Cautionary Reminder Note:
Before attempting any repairs, be sure to unplug the appliance from the wall receptacle power source first.
Read The Sticky Help Note In This Topic:
Range-Stove-Oven-Broiler Basic Help Information & Manufacturers Web Sites. http://forum.doityourself.com/showthread.php?t=159808
Use the reply button to add additional information or questions. Using the reply button keeps or moves the topic back up to the top of the list automatically and keeps all communications on this subject in this thread.
Regards and Good Luck. Web Site Host, Moderator Hiring Agent, Gas Appliances Topic Moderator, Multiple Forums Moderator & Natural Gas Appliance Diagnostics Technician.
Personal Driving Safety Reminder: Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
