Convert At Gas Dryer To Use Of Propane
How Would I And Where Would I Buy A Converter To A Gas Dryer To Be Use Istead Of Gas To Propane?
Thank You,
Rose
Thank You,
Rose
HOW WOULD I AND WHERE WOULD I BUY A CONVERTER TO A GAS DRYER TO BE USED INSTEAD OF GAS TO USE FOR PROPANE, THANK YOU, ROSE
Any store that sells that model dryer should have or be able to get the conversion kit.
In order to convert to propane you need to replace the existing vent limiter on the dryer's gas control and replace the burner orifice.
