GE top burners
Old 10-07-08, 06:32 AM
O
GE top burners
2006 Gas Ge 317b6641p001 stove. Top burners won't ignite. Gas is present. Spark seems to be present too. One burner finally ignited but, three others won't, except with lighter. Odd for all to go at one time?
Thanks in advance,
Lance
Old 10-13-08, 05:41 AM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Hello Lance and Welcome to the Gas Appliances topic.
If the pilot or spark igniter is between two burners or down below a burner, chances are the ignition ports on the side of each the burner is restricted or plugged.
Ignition ports are the tiny holes on the side of each burner. Gas coming out of those holes lights the burner from either a pilot flame or a spark igniter. Clean out the holes using a pin but do not enlarge them.
Additional Advice and Information (pertaining to the above) Here:
Read the Range-Stove-Oven-Broiler Basic Help Informational Sticky Note, in this forums topic, for more detailed information.
Range-Stove-Oven-Broiler Basic Help Information, Fault Codes & Mfg's Web Site Links http://forum.doityourself.com/showthread.php?t=159808
Retail appliance parts dealers can also help determine what the possible problem may be also. They will need the make, model an serial numbers. Appliance parts dealers are an excellent source for original replacement parts. Dealers are listed in the phone book under appliances.
"Be sure the electrical power and the gas supply to the appliance is turned off, before attempting any repairs. Always check for gas leaks whenever the appliance is moved and/or a repair includes any connection of a gas part."
Kindly use the reply button to post all replies, add additional information or ask additional questions when replies are posted. Using this method moves and/or keeps the topic back up to the top of the list of questions automatically and keeps all content on the same subject within one thread.
Web Site Host, Gas Appliances Topic Moderator & Multiple Forums Moderator. Energy Conservation Consultant & Natural Gas Appliance Diagnostics and Repair Technician.
Personal Driving Safety Reminder:
Buckle Up & Drive Safely. "The Life You Save, May Be Your Own."
