Magic Chef Oven/Not keeping correct temp
Old 10-10-08, 06:18 AM
O
Hi, I have a Magic Chef gas range model 6498VTV that is
about 11 years old. The oven gradually over time (about a year) developed a problem. The actual temperature inside the oven does not reach the set temperature on the display. I use a external digital thermometer with the probe in the oven to test/verifyoven temperature .I set the oven to 5oo degrees, wait for the oven to beep indicting it has reached 500 degrees on the keypad. The temperature inside the oven reached 225 degrees and going will go up and down. Touch pad does not show any fault codes, glow ignitor bright red, gas valve comes on, oven burner ignites yet the oven temperture is way off. The convection fan for the
oven runs all the time. Do you think it is the relay board/control unit or the oven temperture sensor?
Any help would be appreciated.
Old 10-13-08, 04:58 AM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Hello opnjim and Welcome to the Do It Yourself Web Site and to the Gas Appliances topic.
Based upon the problems description, I would suggest replacing the temperature senser. That part is prone to wearing out over time and usage. Which can cause the problem/condition described.
Use caution install the replacement part. Temp sensors are delicate items, damage easily and are a non returnable part once purchased and installed.
Cautionary Reminder Note:
Before attempting any repairs, be sure to unplug the appliance from the wall receptacle power source first.
Read The Sticky Advice And Information Note In This Topic:
Range-Stove-Oven-Broiler Basic Help Information & Manufacturers Web Sites. http://forum.doityourself.com/showthread.php?t=159808
Use the reply button to add additional information or questions. Using the reply button keeps or moves the topic back up to the top of the list automatically and keeps all communications on this subject in this thread.
Regards and Good Luck. Web Site Host, Moderator Hiring Agent, Gas Appliances Topic Moderator, Multiple Forums Moderator & Natural Gas Appliance Diagnostics Technician.
Personal Driving Safety Reminder: Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
