GE XL44 gas stove problems
Old 11-27-08, 11:36 AM
Exclamation GE XL44 gas range problems
When using the oven it will heat up to the set temp. but will not kick back on to maintain the set temp. Any ideas of what could be wrong?
Old 11-28-08, 05:55 AM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Hello mrs-fix-it and Welcome to the Do It Yourself Web Site and to the Gas Appliances topic.
If the oven will not turn (kick) back on but the HSI (Hot Surface Igniter) glows, the HSI is weak. Glows but not hot enough to ignite gas in an already warm oven.
Replace the HSI as a first attempt to fix it. Should or may resolve the problem.
Retail parts dealers and appliances parts stores can also help determine what the possible problem may be based upon that specific brand and model. Bring the make, model and serial numbers. Dealers and appliances parts stores are listed in the phone book.
Cautionary Reminder Note:
Before attempting any repairs, be sure to unplug the appliance from the wall receptacle power source first.
Read The Sticky Advice And Information Note In This Topic:
Range-Stove-Oven-Broiler Basic Help Information & Manufacturers Web Sites. Range/Stove/Oven/Broiler Info, Leak Detection, Fault Codes, Fuel Conversion & Links - DoItYourself.com Community Forums
Use the reply button to add additional information or questions. Using the reply button keeps or moves the topic back up to the top of the list automatically and keeps all communications on this subject in this thread.
Regards and Good Luck. Web Site Host, Moderator Hiring Agent, Gas Appliances Topic Moderator, Multiple Forums Moderator & Natural Gas Appliance Diagnostics Technician.
Personal Driving Safety Reminder: Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
