help with old Kenmore gas oven
Old 03-01-09, 06:32 AM
A
Question help with old Kenmore gas oven
I have an older model Kenmore pilot free ignition, continuous self cleaning oven, model # 103.7287810. All four of the burners on the stove work fine, the oven does not. When I turn the oven on I do not smell any gas. I tried to unplug & replug it in. I made an attempt at relighting the pilot but it does not light. Any suggestions?
Old 03-01-09, 08:27 AM
H
Being your range is "pilot free" there is no pilot to relight in the oven. Your oven burner is lit from a hot surface igniter. It is common for these to go bad and need replacing.
More information regarding the subject and can be found at this sticky:
http://forum.doityourself.com/kitchen-gas-appliances/159808-range-stove-oven-broiler-info-leak-detection-fault-codes-fuel-conversion-links.html
