Whirlpool LGR4624 Gas Dryer
Hi, I have a Whirlpool gas dryer that was converted to LP. I have moved and want to remove the conversion and use nat gas again. Is this possible and how do I do it? I cant find literature anywhere on it. Thanks.
Were the old parts saved? You'll need to buy a conversion kit. Most kits are sold to convert from NG to LP, not the other way around. You'll probably have to buy the parts piecemeal if they were not saved. Try looking at the base of the gas valve to see if the kit part numbers are there. It's probably best to have a technician reconvert for you.
