testing (Gas Dryer) igniter
Old 07-12-09, 05:39 AM
whirlpool gas dryer stopped heating,is there any way to test igniter?
Old 07-12-09, 06:39 AM
Sharp Advice's Avatar
Admin Emeritus
Received 5 Votes on 4 Posts
Hello sjay and Welcome into the Gas Appliances topic.
IMO, there usually isn't any real need to test an igniter. If the igniter is more then two years old, chances are it needs replacement. Not to expensive to buy nor to difficult to replace.
You didn't explain why you're assuming the igniter needs to be replaced.
Exactly stated, in complete details, what are the symptoms of the dryer???
Kindly explain in full details. Once we know the problem(s) we can then best provide one or more possible solutions. Best to read the dryer sticky note. Likely to find the solution faster and much sooner then awaiting any reply....IMO
Additional advice and information HERE:
Retail appliance parts dealers can also help determine what the most likely possible problem may be. They will need the make, model and serial numbers. Appliance parts dealers are an excellent source for original replacement parts and problem resolving matters. Dealers are listed in the phone book under appliances.
Be sure the electrical power to the appliance is turned off, before attempting any repairs or services. Always check for gas leaks whenever moving the appliance and/or a service or repair includes any connection of a gas part.
Read the existing questions on the subject of dryers. Doing so will more quickly provide you with answers to questions & provide additional information on how to resolve dryer problems.
Web Site Host, Forums Manager, Moderator Hiring and Promotions Agent, Gas Appliances Topic Moderator, Multiple Forums Moderator & Natural Gas Appliance Diagnostics Technician.
DRYER SERVICE TIP:
It's always advisable to clean the entire exhaust venting system every 2 years. Or during any dryer maintenance, replacement and or repairs.
Old 07-12-09, 10:22 AM
"You didn't explain why you're assuming the igniter needs to be replaced."
yes i did,dryer stopped heating was my only statement,and only one simple question can igniter be tested. not how much it costs but can it be tested.
Old 07-13-09, 03:39 AM
pugsl's Avatar
Received 76 Votes on 69 Posts
Yes Igniters are closed any open circuit is bad in igniter, many reasons dryers don't heat igniter only one.
Old 07-24-09, 06:29 AM
H
Originally Posted by sjay View Post
....and only one simple question can igniter be tested?
The simple answer is yes.
