Whirlpool gas dryer
Old 08-06-09, 10:52 AM
D
Whirlpool gas dryer
HELP! I have a whirlpool gas dryer and it is not heating, what do I do?
Old 08-06-09, 02:13 PM
pugsl's Avatar
Received 76 Upvotes on 69 Posts
post model # so we can see which dryer you have
Old 08-06-09, 03:30 PM
D
model number LGR6848AW2
The model number is LGR6848AW2. Any help would be greatly appreciated.
Old 08-07-09, 04:29 AM
pugsl's Avatar
unplug dryer first
Here is where to start. part # 7 is the thermo fuse.
WHIRLPOOL | Model #LGR6848AW2 | GAS DRYER | BULKHEAD | SearsPartsDirect.com
Should have continuity (closed) you have to take back off dryer to check. let us know how it's going. Does fryer turn on at all?
Old 08-12-09, 06:44 PM
C
my 13 yo whirlpool quit heating years back. the thermal switch had a broken connection =REALLY cheap/small rivet = put in nut/bolt = fine ever since.
i am now back. beacuse it again, stopped heating. the switch is fine still. its something else.
whirlpool = pos.
Old 08-13-09, 03:14 AM
pugsl's Avatar
post model #, first ckeck door switch and thermo fuse.
Old 08-13-09, 07:22 PM
C
i misspoke. not thermal switch. flame switch.
anyway. after posting, i found the HOW TO. it said that when turned on, the igniter should start to glow. mine does not.
LGR7646EQO
our (wife and i only) machines don't get a lot of use, about 3 loads a week.
Old 08-15-09, 02:04 PM
pugsl's Avatar
Need ohm meter to ck. Will show a closed circuit ( open is bad)
Old 08-16-09, 08:06 AM
C
just checked it. looks good. meter showed around 70ish ohms. whats next ? thanx
Old 08-17-09, 03:33 PM
pugsl's Avatar
have been out of town, just got back while you have dryer open ohm gas coils and the flame sensor. All should show a circuit coils will have a higher reading than sensor. If all show circuits take back off and check thermo fuse.
Old 08-17-09, 07:29 PM
C
ok. i found my problem.
on the back exhaust vent. there is a white thermal switch, bout 1 1/2" long and 1/2" wide. 2 prong. i disconneted the 2 terminals and taped em together. the heat started working.
thanx Beer 4U2
now, i gotsa git 1, fur my wife drives me crazy.
Old 08-18-09, 03:33 AM
pugsl's Avatar
That is the thermo fuse, get it replaced and clean vent to outside or you will be be doing it again.
Old 08-18-09, 07:06 PM
C
the vents to the outside are cleaned by a company every year. per the condo ass.
