Kenmore Range 362.75675691
Oven won't heat. The glow plug is working visually. Removing the oven bottom plate, I see when gas comes on, it is little to almost no pressure. The broiler side works great along with all stovetop burners. I flipped the valve around for broiler and oven burners supply. I would turn on broiler, igniter for broiler would light. When I heard gas turn on, I lit oven burner with a lighter. Had full flame. Did same oven glow plug, turned it on, gas turned on at broiler, I hand lit with a lighter. Had full flame on each burner. So I put valve back on in the correct way, and gas pressure to oven was little to none again. Hope I am not cofusing this. Seems like when I reversed valve, I had full pressure both ways. Normal way only to broiler. Any ideas?
Thanks
Dave
Thanks
Dave
