Diffrence between Frigidaire Part Nos. 316119302 & 5303935068
I have Frigidaire Gas Oven Model No. FGF379WJCA. I would like to replace the Broil Ignitor on this stove as I think it has lived its life. The part no. as per the Stove's literature is 316119302. But searching the internet, I found another Frigidaire Ignitor Part No. 5303935068 which looks exactly similar to the one that is as per the Stove's literature. I can get 5303935068 much cheaper than the other one on Ebay. But I want to make sure that it will work.
Can anyone tell me what could be the difference between the two.
Thanks
Subhash
Thanks
Subhash
Received 7 Upvotes
Hello Subhash . Welcome to the Gas Appliances topic and the Do-It-Yourself Web Site.
Best advice to offer is check with a local appliances parts retail store. Best insurance for obtaining the correct part.
Looks like the part or similar to the existing part may not be the correct part nor one that is interchangeable with the OEM part...
HSI's (Hot Surface Igniter's) function by electrical resistance. Not looks. Wrong part creates more problems....
then it resolves, if any. Best bet. Buy locally and be sure.
Buyer Beware:
Electrical parts and/or components are non returnable and non refundable. Once purchased, especially online, you own it whether it is the correct part, works or does not work, solves the problem or doesn't. You bought. Done deal....
Read the "fine" print before buying.
BTW: Never mentioned any problem, condition and/or symptom that would warrant replacing the HSI......
Additional Advice & Information Located:HERE
"Be sure the electrical power and the gas supply to the appliance is turned off, before attempting any repairs. Always check for gas leaks whenever the appliance is moved and/or a repair includes any connection of a gas part."
Kindly use the reply button to post all replies, add additional information or ask additional questions when replies are posted. Using this method moves and/or keeps the topic back up to the top of the list of questions automatically and keeps all content on the same subject within one thread.
Web Site Host, Gas Appliances Topic Moderator & Multiple Forums Moderator. Energy Conservation Consultant & Natural Gas Appliance Diagnostics and Repair Technician.
Personal Driving Safety Reminder:
Buckle Up & Drive Safely. "The Life You Save, May Be Your Own."
Buyer Beware:
Thanks for the reply.
The problem I am having is that the Oven does not work anymore. It was worked fine around 7pm when I warmed up something. I turned it off and then about 9pm I tried to turn it on again but it didn't come on. The Glowbar does not work anymore. So, I am sure it is the Ignitor.
I basically wanted to know if anyone knows the specs difference between the two part nos. I quoted in my first post.
Norton 3.2-3.6 amps
Carborundum 2.5-3.0 amps
These two parts are basically the same. Part 316119302 will have to correct connector for your model oven. Part 5303935068 will not; it will just have bare wires and 2 porcelain wire nuts with instructions on how to install it. My local parts supplier sold me 5303935068 and said this is what the repairmen carry with them because they can use them on many ovens, regardless of the specific connector the oven needs. The part is the same and you can save money buying the more generic part with bare wires. Just wire in the connector from your old part (assuming the connector is still good)
WARNING: don't do what I did and short out the gas safety valve in the process of replacing it. Don't let the ignitor wires touch anything while you replace it.
