Gas Oven Won't Light
Old 01-16-00, 08:00 AM
Guest
Question
I have a natural gas stove/Oven my guess is less than 10 yrs old (not sure) that has the brand name Capri on the front. The oven burner will not light. When I look into the broiler part at the bottom, I can see the pilot light is lit, constatnly burning. When I turn on the oven, I hear the gas, and see the pilot grow to double or three times it's normal size. However, the flame does not catch on to the small holes on the long 'burner' and extend toward the front of the broiler. Any help appreciated.
Old 01-16-00, 09:23 PM
Guest
Post
Hello: MJB
I read two different versions in your posting of the symptom. One is serious, the other is no problem. I will cover both here.
You say you HEAR gas:
If you HEAR BURNER gas flowing, you have a more serious problem but NOT a repair problem.
My advice here is NOT to use the oven until it's checked out by your gas utility company service rep. <If the utility provides service> or a local appliance agency.
The problem here is:
That larger pilot heats the burner safety element. <ASO> When it gets HOT it opens and allows the burner gas out. That larger pilot flame also is the source of ignition to the burner gas.
If that burner gas is allowed to continue to come out, soon the oven will fill with gas and ignite. That delayed ignition will explode and blow open the oven door, at the very least.
<Therefore DON'T use it until it's fixed.>
The fix to a pro is easy. Clear the large pilot flame of dust and/or realign the large pilot to the burner. Easy fix without parts.
If you only HEAR pilot gas, but the burner won't turn on, it's most likely the burner safety valve that won't open.
In this case, either the pilot is restricted and needs to be cleared or the burner safety element is defective and will need to be replaced.
Contact your gas supplier or utility for service first. It just may be a free fix.
Good Luck
Sincerely,
TomBartco
TomBartco Enterprises.
Trade:Natural Gas Energy Consultant & Technician.
Appliance Service & Repairs Rep.
Vocations:Saw & Tool Sharpening. Small Engine Repairs.
Accurate Power Equipment Company.
E-Mail:TomBartco@doityourself.com
Personal Quote:
"Drive Safely. The Life You Save, May Be Your Own."
Old 02-08-02, 08:18 PM
trendar
I'm experiencing the same problem, which Tom's posts here and Jeff have led me to believe the fluid safety is out of whack or bad-
But my question is, why is it apparently unlikely for the thermostat to cause this problem, where the pilot runs up, but the main gas never kicks in?
From what I've read, there are possible two methods for controlling oven temperature, with these constant pilot systems:
1- cutting down the gas pressure to the pilot, (back to the standby position), which subsequently shuts off the gas via the safety valve- (are there actually two separate pilot orifices? Or just a decrease/increase in the supply pressure to the same pilot?)
2- cutting off the gas supply to the main burner itself-
Why is is so much less likely for the thermostat mechanism to fail in the stuck closed position?
Or is this a matter of normal diagnostic methods, to first check the less expensive type of problems before going on to the hard stuff?
