replacing thermostat on Whirlpool dryer
Old 02-23-00, 05:18 PM
Guest
Post
I have been told to replace the thermostat on the heating element on my approxiametly 10 year old whirlpool dryer. My only problem is, how do I access the thermostat. It is in a very akwars position, on the floor of the dryer on the left side.
Old 02-23-00, 05:36 PM
Guest
Post
Hi avid B.
If you have already been told to replace the T-Stat sensor, and it's located where you say it is, you should already should have the front panel removed.
That sensor, if we are both talking about the same part, should be on the discharge side of the exhaust fan.
If it appears to be in a difficult location and you think you might draw blood from a cut, proceed carefully.
If you do actually do cut yourself and draw blood, now that becomes an addition charge on the bill...hahaha
If you do not already have that part, post exactly what the dryer ISN'T doing. This way we might help you further. I suspect that part may not even be the fix your dryer needs. Elaborate more on the symptoms.
Good Luck
Sincerely,
TomBartco
TomBartco Enterprises.
Trade:Natural Gas Energy Consultant & Technician.
Appliance Service & Repairs Rep.
Vocations:Saw & Tool Sharpening. Small Engine Repairs.
Accurate Power Equipment Company.
Personal Quote:
"Drive Safely. The Life You Save, May Be Your Own."
Old 02-23-00, 05:47 PM
Guest
Post
Whirlpool dryer
Model LHI7801
The problem I have with my dryer is that it does not get hot enough when
drying. This problem is also exhibited on the timed dry cycle, the
clothes still come out damp. What part can be used to fix this?
I have already tried cleaning the exhaust duct and all lint, but to no avail.
