whirlpool gas oven knob
Old 04-22-00, 11:01 AM
chetmichaels
Thumbs up
I've got a whirlpool gas rang, model no. SF317PEXN0 (that's a zero), and the numbers on the oven knob is all wiped out. It'll cost $27 to replace it, but all I need is the degree ticks. Does anybody have this oven and can tell me where what number goes or knows where to see a picture of it? It turns counterclockwise. Thanks, Chet
Old 04-22-00, 07:36 PM
Guest
Post
Hi:chetmichaels
Only point to know about ALL oven thermostats is that exactly 180 degrees from the OFF position is 350 degrees.
Mark yours where the OFF position is.
Then rotate the knob exactly 180 degrees and mark that spot 350 degrees.
Next, continue to rotate from 350 until you hear a tiny click. That point, just prior to the click, will then be the 550 degree setting and just after that click will begin the BROIL position.
HINT:
Granted, $27.00 is a total rip-off for a knob. However, ANY oven knob that will fit the thermostat shaft will work, if your not picky about looks.
Therefore, check for one in any hardware store, second hand store or used appliance store.
Good Luck
Sincerely,
TomBartco
Trade:Natural Gas Energy Consultant & Technician.
Appliance Service & Repairs Rep.
Vocations:Saw & Tool Sharpening. Small Engine Repairs.
Accurate Power Equipment Company.
Personal Quote:
"Drive Safely. The Life You Save, May Be Your Own."
Old 04-24-00, 07:18 AM
chetmichaels
Talking
thanks! made my day
chet
