Gas leak from oven
Old 12-21-09, 10:45 AM
T
Gas leak from oven
my in-laws gave us a stove. it works great but it is leaking gas from the oven when its off. what could be causing this? thanks
Old 12-24-09, 07:32 AM
Sharp Advice's Avatar
Admin Emeritus
Received 5 Votes on 4 Posts
Hello ?????? and Welcome to the Do It Yourself Web Site and to the Gas Appliances topic.
Apologies for such a late reply.....
Most likely cause is the oven burner gas control valve, the rectangular metal device the end of the burner tube rests on, is allow a small amount of gas to pass through it when in the closed non operational position. Very much like a very slow leaky or drippy water faucet.
Solution is to either replace it or have it replaced. Not all that difficult to due if one is handy with small tools and uses cautions during the process. Then upon completion tests for leaks where part is connected using leak detection soap.
Much more info HERE
Retail parts dealers and appliances parts stores can also help determine what the possible problem may be based upon that specific brand and model. Bring the make, model and serial numbers. Dealers and appliances parts stores are listed in the phone book.
Cautionary Reminder Note:
Before attempting any repairs, be sure to unplug the appliance from the wall receptacle power source first.
Use the reply button to add additional information or questions. Using the reply button keeps or moves the topic back up to the top of the list automatically and keeps all communications on this subject in this thread.
