whirlpool gas range
Old 09-07-00, 05:06 PM
Guest
Post
Brand new whirlpool gas range model SF385PEGn 5. The oven and broiler will start intermittently. Whirlpool techs replaced microprocessor and spark module with no success. Tried to plug unit to a different outlet with no success either
Old 09-07-00, 07:16 PM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Post
Hi:sun4d98
There seems to be a lot missing in your post unless I am missing something here. Are they continuing to to fix it? If so, allow them to do as they think best. It's still under warranty at this point.
You haven't mentioned if they are returning, still working on it? What's the statis at this point? You able to use it? Did they restrict the useage of the oven and broiler until new parts come in? What did the tech say was the next step?
Personally, I doubt if the tech can't fix it. Maybe not on the first call, but hopefully on the return call.
If and when they finally determine it cannot be fixed, which I doubt, get the whole stove replaced.
Good Luck,
TomBartco
