Kitchenaid gas oven contol panel problem
Old 01-03-10, 11:29 AM
W
I have an 8 year old kitcheaid slide-in gas range. The control panel display contines to come on with a tempertature setting and the "start?" indicators lit. This statrted slowly but is now happening several times per hour. No "fault code" has appeared.
Old 01-06-10, 04:15 AM
Sharp Advice's Avatar
Admin Emeritus
Received 5 Votes on 4 Posts
Hello wrh4883 and Welcome to the Do It Yourself Web Site and to the Gas Appliances topic.
Based upon the problem description, I would suspect the main control board is defective. A replacement new board likely to be the only solution.
Retail parts dealers and appliances parts stores can also help determine what the possible problem may be based upon that specific brand and model. Bring the make, model and serial numbers. Dealers and appliances parts stores are listed in the phone book.
Additional Suggestions:
Read the manufacturers on line web site for product information, problem possibilities, causes, solving methods, part locations, disassembly, reassembly methods, repair procedures, pictorials, schematics, repair and or owners manuals which may be available on line.
Cautionary Reminder Note:
Before attempting any repairs, be sure to unplug the appliance from the wall receptacle power source first.
Read The Sticky Advice And Information Note In This Topic:
Range-Stove-Oven-Broiler Basic Help Information & Manufacturers Web Sites. Range/Stove/Oven/Broiler Info, Leak Detection, Fault Codes, Fuel Conversion & Links - DoItYourself.com Community Forums
Use the reply button to add additional information or questions. Using the reply button keeps or moves the topic back up to the top of the list automatically and keeps all communications on this subject in this thread.
