Maytag Gas Stove LCD Display
Old 01-05-10, 07:21 AM
H
Thumbs down Maytag Gas Stove LCD Display
The display went blank while using the oven. Is there a in line fuse to this display board?
How do I remove the board & replace it?
Old 01-06-10, 05:02 AM
Sharp Advice's Avatar
Admin Emeritus
Received 5 Votes on 4 Posts
Hello hwh888. Welcome to the Gas Appliances topic.
No known fuse to the main board.
To access electronic components you'll have to first remove electric plug from wall outlet. Then remove the front display panel. Then wire quick disconnects to board, etc.
Full and complete step by step instructions not possible in this type of text only format and much to detailed to explain here. However, may be possible to access details in a service manual obtainable at a local appliance parts store.
Retail parts dealers and appliances parts stores can also help determine what the possible problem may be based upon that specific brand and model. Bring the make, model and serial numbers. Dealers and appliances parts stores are listed in the phone book.
Additional Suggestions:
Read the manufacturers on line web site for product information, problem possibilities, causes, solving methods, part locations, disassembly, reassembly methods, repair procedures, pictorials, schematics, repair and or owners manuals which may be available on line.
Cautionary Reminder Note:
Before attempting any repairs, be sure to unplug the appliance from the wall receptacle power source first.
Read The Sticky Advice And Information Note In This Topic:
Range-Stove-Oven-Broiler Basic Help Information & Manufacturers Web Sites. Range/Stove/Oven/Broiler Info, Leak Detection, Fault Codes, Fuel Conversion & Links - DoItYourself.com Community Forums
Use the reply button to add additional information or questions. Using the reply button keeps or moves the topic back up to the top of the list automatically and keeps all communications on this subject in this thread.
Regards and Good Luck. Web Site Host, Moderator Hiring Agent, Gas Appliances Topic Moderator, Multiple Forums Moderator & Natural Gas Appliance Diagnostics Technician.
Personal Driving Safety Reminder: Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
