Lube for natural gas valve
Old 04-07-10, 08:38 AM
firedude2894's Avatar
I need to lube a few natural gas valves (one on a Magic Chef stovetop and one on our natural gas fireplace) Since they have gotten a little stiff over the years.
What type of lube should I use with natural gas valves.
Thanks in advance.
Old 04-07-10, 08:18 PM
Speedwrench's Avatar
graphite is the only lube that you should use for that.
murphy was an optimist
Old 04-09-10, 12:56 PM
SeattlePioneer's Avatar
Received 1 Upvote on 1 Post
Actually, there's a special gas valve grease you should be able to get at appliance or plumbing supply shops.
The stuff I used when I was a utility gas fitter was Johnson Controls Gas Valve Grease Y70AA-1.
