How to Get the Black baked on gunk out of the oven
Old 12-05-00, 09:56 AM
thekeymaker
Lightbulb
ok i'm trying to clean a Stove out. how many people have the black stuff that is hard to scrape off that is what i have. but i would like to remove it so the oven is more cleaner then what it is now. anyone have any suggestion's Don,
Old 12-05-00, 11:32 AM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Lightbulb
Hi:Keymaker
The best idea I could offer you is to post this question in the cleaning forum on this site. There you'll get the professional advice of Mary Moppins.
The only suggestions I could offer you is to remove the removeable panels, racks, etc. and put them outside somewhere and spray them with oven cleaner.
Then spray the inside of the oven compartment and follow the directions on the product can.
TIP:
DO NOT spray the tube element <capillary tube> inside the oven. This tube is the temperature sensor and it should be located at or near the top of the oven compartment. Should be held in place by two clips.
I'm sure there are other solutions for cleaning the difficult baked on spots. You should be able to get better suggestions from Mary.
Good Luck,
Tom
