Jenn-Air Range Display issues
Old 08-27-10, 08:26 AM
B
I have a Gas/Electric hybrid range from Jenn-Air, model no. SVD48600W. It was present in the townhome that I moved into. Recently, the LCD display brightness has greatly decreased, to a point that you can barely see it even when the room is dark. I had to open the door to confirm that the range had power. Is this a common problem, and is this a correctable problem? Or is this just the beginning of the end (range is 15+ years old)?
Thanks,
Ben Rupe
Old 08-28-10, 07:47 AM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Hello Ben. Welcome to the Gas Appliances topic.
Chances are the display panel is worn out and needs to be replaced... Part is available at a local appliance parts store....
Bring the make, model and serial numbers. Dealers and appliances parts stores are listed in the phone book.
Additional Suggestions:
Read the manufacturers on line web site for product information, problem possibilities, causes, solving methods, part locations, disassembly, reassembly methods, repair procedures, pictorials, schematics, repair and or owners manuals which may be available on line.
Cautionary Reminder Note:
Before attempting any cleaning or repairs, be sure to unplug the appliance from the wall receptacle power source first.
Read The Sticky Advice And Information Note In This Topic: Range-Stove-Oven-Broiler Basic Help Information & Manufacturers Web Sites. Range/Stove/Oven/Broiler Info, Leak Detection, Fault Codes, Fuel Conversion & Links - DoItYourself.com Community Forums
Addition advice may be located here:
Maytag Appliance Home Page:
http://www.maytag.com
Maytag 1-800-688-9900 USA
Maytag 1-800-688-2002 Canada
Maytag is also the maker of Amana, Jenn-Air, Magic Chef and Caloric Appliances.
Use the reply button to add additional information or questions. Using the reply button keeps or moves the topic back up to the top of the list automatically and keeps all communications on this subject in this thread.
