Jenn-air seg196 Fan/Light Switch
Hi, I need to replace the fan/light switch on my Jenn-air seg196 range. When I removed the old one (which had fallen to pieces) I made a wiring diagram, but now that I have the new part, I can't seem to find my diagram. Would anyone have a wiring diagram for this or know which color wire goes to which terminal on the switch?
Thanks!
Thanks!
Received 7 Upvotes
Hello sbaylus. Welcome to the Gas Appliances topic and the Do-It-Yourself Web Site.
Somewhere, often out of most common area of visual sight and/or hidden on the appliance, will be a wiring diagram. Might be in the back of the appliance, tucked away in a frame rail, behind a front or rear panel or under the top lid, etc. You'll need to search around and look for it. Unless someone before you needed it and did not replace it or did but not in the same location, etc.
You might be able to obtain a print out of the wiring diagram from a local appliance parts store. Especially if you purchased the part at the store. Often times in my prior experiences, the retail store is willing to provide such help to satisfy their customers and keep them coming back to their store. Better known as "Customer Service."...
Maytag Appliance Home Page:
http://www.maytag.com
Maytag 1-800-688-9900 USA
Maytag 1-800-688-2002 Canada
Maytag is also the maker of Amana, Jenn-Air, Magic Chef and Caloric Appliances.
Jen Air Appliance Home Page:
http://www.jennair.com
Repair Manuals:
Uncle Harry's Online Appliance Repair Manuals, Videos, and Training
Range-Stove-Oven-Broiler Basic Help Information, Fault Codes & Mfg's Web Site Links Range/Stove/Oven/Broiler Info, Leak Detection, Fault Codes, Fuel Conversion & Links - DoItYourself.com Community Forums
Repair Manuals:
