gas leak from flex pipe and black steel connector
I own a old whirpool gas dryer without a shut off switch. As was coming out fast from the flex hose and there's a small thin hair line seeping gas from the long black gas line connected to the flex hose. The gas was shut off to stop the gas. My question is, should we call a repair plummer or could we fix it ourselfs? The gas company explained what parts we need. We are not sure what to do
Please help
Please help
A plumber should be able to fix this in a very short time. If you do not have the tools or expertise the cost of the required items could be just as much as his charges. Also, if you do it wrong it could be very dangerous. If you can do w/o gas service for a day or 2 (furnace, cooking, etc) a plumber may be able to fit in a call w/o making it an emergency response (which = more $$$).
If it was just the flex supply line, I'd say go get a valve and put it on, but your description seems to indicate a crack in the black iron supply piping itself.
