Stackable washer/dryer
Old 01-14-11, 05:34 PM
D
I have to move a stackable washer/dryer from the garage to the house tomorrow. I can't figure out how to separate the two. They are located under a shelf and can't be moved out unless we demo the shelf. Any ideas?
Old 01-14-11, 05:40 PM
lawrosa's Avatar
Super Moderator
Received 59 Votes on 51 Posts
What is the make and model #.
Mike NJ
Old 01-14-11, 06:50 PM
D
It is a Fridgeaire, but I don't know the model. I just need to separate the two parts so I can move them.
Old 01-15-11, 03:36 AM
pugsl's Avatar
Received 62 Votes on 58 Posts
Need model # some of units don't come apart and some do. If they do look for 2 plastic plugs under dryer. there are screws there to remove and dryer will come off.
Old 01-15-11, 05:05 AM
chandler's Avatar
Received 5 Votes on 5 Posts
If you can't move them out as a pair due to the shelf, you won't get them out individually with the shelf. Bottom line, the shelf may need to go, or be temporarily removed until the WD are moved. If your plans are to leave them stacked, move them as a unit on handtrucks. Saves a lot of work.
Old 01-15-11, 07:38 AM
D
Thank you. I'll try that when I get to the site.
Old 01-15-11, 07:44 AM
D
Looks like I'll have to raise the shelf after all. And I have a fridge dolly. Thanks.
