Burner Issue's
Old 06-06-11, 12:07 PM
A
Burner Issue's
Have a Whrilpool super capacity 465 in which the back two burners do not light. I have already cleaned all burners with arm&hammer baking soda but same issue. What can I do to fix this issue?
Old 06-07-11, 05:54 AM
Sharp Advice's Avatar
Admin Emeritus
Received 5 Votes on 4 Posts
Hello alejandro44. Welcome to the Gas Appliances topic and the Do-It-Yourself Web Site.
First thing that needs to be done is post more specific and detailed information.
Do the sparkers spark?
Can the burners be manually lighted with a match?
If no, then there is no gas to the burners. If yes, there is gas and flames.
Very likely the answers are in the sticky note Range-Stove-Oven-Broiler Basic Help Information, Fault Codes & Mfg's Web Site Links Range/Stove/Oven/Broiler Info, Leak Detection, Fault Codes, Fuel Conversion & Links - DoItYourself.com Community Forums
Retail appliance parts dealers can also help determine what the possible problem may be also. They will need the make, model an serial numbers. Appliance parts dealers are an excellent source for original replacement parts. Dealers are listed in the phone book under appliances.
"Be sure the electrical power and the gas supply to the appliance is turned off, before attempting any repairs. Always check for gas leaks whenever the appliance is moved and/or a repair includes any connection of a gas part."
Kindly use the reply button to post all replies, add additional information or ask additional questions when replies are posted. Using this method moves and/or keeps the topic back up to the top of the list of questions automatically and keeps all content on the same subject within one thread.
