Maytag Dryer wont run
Old 11-01-11, 04:51 PM
Relatively new (2 years old) Maytag epic z Model #MEDZ600TW2
It powers up and the lights on the control panel work.
I did the fault code check and came up with F01. I replaced the machine control electronics.
Still wont run.
Turning the knob and pushing the buttons adjust the controls accordingly but the dryer just wont run.
Any suggestions please?
Old 11-01-11, 06:49 PM
A little more information. I am not getting anymore fault codes but only a "88."
The timer runs down.
When i push start, i can hear a click on the machine control electronics and a low "hum" but the drum isnt turning and i dont think it is heating up.
Also, it is an electronic dryer.
Old 12-11-11, 07:58 AM
C
Maytag Dryer Buzzer
Our Maytag gas dryer buzzer won't shut off. The only way to keep it from buzzing is using the dryer or opening the door after it has finished. Just happened yesterday. Can't find anything in the booklet about what the cause is. Any suggestions on how to fix it?
Old 12-11-11, 04:19 PM
pugsl's Avatar
Received 71 Votes on 64 Posts
need model #to know what dryer you have. Usual causes are door switch stuck or buzzer bad.
Old 12-14-11, 02:25 PM
C
Thanks Pugsl - it did finally stop after fooling around with the knobs and starting it up again. Something must have been stuck or dial must have been slightly off - appreciate your input.
Love this sight!
