oven wont work
oven wont work
Hello I'm new to this I have a caloric heritage series stove my oven started acting up by not keeping temp i would bang on the tube by the igniter then it would kick back on. Now I cant get it to work at all the igniter won't work the burners ontop work fine. The model # is Rls359 serial # is 9204226938 any advice would be great thanksgiving is two days away and we dnt have an oven wife is not happy thx again
Well it was probably the igniter at first. After banging and the igniter does not glow, you may have broken a wire in the gas valve. If the igniter still glows I would replace the igniter unless you have the meter to test it first.
Thx ya the igniter doesn't glow or do i smell gas when i turn on the oven. When i would bang on the burner it would kick the burner on almost like the gas wasn't coming out. Then like I said all of a suden the igniter wouldn't come on either. So i will try to get an igniter to see if that works but first I will test it.Now the oven switch on top seems like it isn't getting power it says it is 120 but when i put the meter on it it has nothing not real sure about gas stoves never worked on one but if i.can fix it cheaper than a new stove that would be great! Thx again
You probably had a weak ignitor that wasn't getting hot enough to open the gas valve reliably and light the gas.
Often a weak ignitor will fail completely, at which point the oven wont turn on at all.
Banging on the range while the ignitor was hot might have broken it, but I wouldn't blame you for that absent better information and it was a defective part anyway!
As a furnace and gas appliance repairman, I had better methods than bashing the appliance to effect repairs. On cars though, I find a good bashing is often worth a try!
