Whirlpool Accubake Oven does not work
Old 11-27-11, 05:22 PM
R
Whirlpool stove (model # GW395LEPS03) control panel clock works but other buttons do not work. unable to turn oven on, burners work fine but not controlled by this control panel. No apparent damage to circuit or cables. I found a new control panel circuit board for sale but it is expensive. could it be something else? is there a separate touch pad?
Old 11-27-11, 07:09 PM
SeattlePioneer's Avatar
Odds are the circuit board needs to be replaced.
I doubt I could be of much help over the internet in eliminating other possibilities.
The basic method of diagnosing such problems is the "black box" method. It presumes you have a black box about which you know nothing except that it has various inputs and outputs.
If you have the proper inputs, you should have specific outputs. If you don't--- replace the black box.
You'd have to come up with your own tests for additional confirmation. Based on your previous post it sounds like you probably have the right inputs but aren't getting the right outputs.
You have power to the circuit board because the clock works.
Old 11-28-11, 09:45 PM
R
Thanks....it does sound like a new circuit board
