useless spinning washer
I washed an older blanket today which promptly fall apart into billions of tiny wet soggy crumbs. I cleaned out all the residue & on the next load (it's Saturday, I had 12 loads down and 8 to go...) it seemed to be fine until the spin cycle. It sounds like it's spinning but it doesn't. Is this soemthing we can take care of ourselves or will I be waiting on a friendly repairperson with my check book?
It's a Whirlpool Ultimate Care LSQ9244EQO. Thanks in advance!
Received 7 Upvotes
Hi:tcsjt
I suggest you post this topic in the forum for electric appliances. In that forum you should be able to get the help needed.
Sorry, I only deal with gas appliances in this forum.
I would run the washer again with the lid open (make sure you hold the switch to make it think the lid is closed) and see if the drum ever spins. My guess is that it won't. First, if there is a cap at the top of the center spindle, take it off and tighten any nut hidden below it, re-install the cap and make sure it is snug. If that does not fix the problem, take off the back panel and see if the belt is broken. Some machines don't use belts and instead use a rubber isolation bushing (works like a car's universal joint). If this bushing is bad, there is usually a pile of rubber shavings on the floor. Hope this helps.
