every thing always damp--Lg gas dryer
Old 11-08-12, 06:34 AM
B
It is an LG model DLG 5002W ,serial 008KWJU00076 .Evey thing come out a little damp.I believe its only two years old.The burner is on any time I have looked at it,the exhaust vent is is not blocked and is warm.
Old 11-08-12, 06:47 AM
B
Received 37 Votes on 34 Posts
Have you checked the air flow at the exhaust when running to be sure it is robust?
What type of ducting is in place from dryer to outside, flex or smooth metal duct?
Bud
Old 11-08-12, 03:26 PM
pugsl's Avatar
Received 71 Votes on 64 Posts
easiest way to make sure vent to outside is clean and not blocked is to disconnect it from dryer and dry 1 load to see how dryer works. Another way is disconnect vent turn dryer on feel air flow reconnect vent go outside and feel air flow should be the same. Reason we are concerned about vent is 95% of all dryer problems start with vent troubles.
