Range burner doesn't light
Old 12-21-12, 03:00 PM
I have an old Whirlpool counter top four-burner gas range - with a downdraft fan in the center. Only one of the burners does not ignite. It does not make the sparking noise at the appropriate dial setting. I have the burners exposed and don't see what needs to be repaired or replaced. Also, where is the product ID? Buried beneath the counter somewhere?
Old 12-22-12, 06:09 AM
Sharp Advice's Avatar
Admin Emeritus
Received 5 Votes on 4 Posts
Hello John. Welcome to the Gas Appliances topic and the Do-It-Yourself Web Site.
If that one inoperative sparker does not work with the burner it is connected to, then the most likely cause (defective part) is the switch located on top of the valve stem. If the sparker does work (spark) when any other burner is tuned on, again, it's the switch. If the effected sparker does not ever spark regardless of which burner is being lighted, then the sparker itself is likely to be defective.
The ID plate most likely is in one of two locations. Under the top lid beneath the burners or may be attached to the underside of the counter top unit. Visible from looking under the unit inside the cabinet unit is installed in.
Retail appliance parts dealers can also help determine what the possible problem may be also. They will need the make, model an serial numbers. Appliance parts dealers are an excellent source for original replacement parts. Dealers are listed in the phone book under appliances.
Additional Advice and Information Here:
Read the Range-Stove-Oven-Broiler Basic Help Informational Sticky Note, in this forums topic, for more detailed information.
Range-Stove-Oven-Broiler Basic Help Information, Fault Codes & Mfg's Web Site Links http://forum.doityourself.com/showthread.php?t=159808
"Be sure the electrical power and the gas supply to the appliance is turned off, before attempting any repairs. Always check for gas leaks whenever the appliance is moved and/or a repair includes any connection of a gas part."
Kindly use the reply button to post all replies, add additional information or ask additional questions when replies are posted. Using this method moves and/or keeps the topic back up to the top of the list of questions automatically and keeps all content on the same subject within one thread.
Old 12-22-12, 09:06 AM
Received 1,112 Votes on 1,032 Posts
On Whirlpool cooktops they put the ID plate under the unit on the bottom.
Old 12-22-12, 11:51 AM
I discover that the unit does light when the one to its rear is alight. I guess we can live with that. I've not found the ID plate as yet but will look further so I can finds the part I need.
Thanks for all your help.
