New GE stove flaming
Old 01-13-13, 10:32 AM
B
Brand new GE convection oven replacing our original oven - both propane. New oven came with gas conversion. Installed and the flames are huge! Top burners have flames 6-8" high and must be used down at the lowest settings. The oven has flames up through the bottom vents and the broiler has flames lapping out the top far enough to contact the inner door if it's shut. Area between the knob gets very hot then as well. Tried both nozzles (LP and natural gas) and no change. Thoughts and suggestions?
Old 01-13-13, 11:05 AM
GregH's Avatar
Super Moderator
Received 35 Votes on 33 Posts
You need to ensure that the gas pressure is correct for the stove you purchased.
A service call to check the installation and check the gas pressure might be a good idea in case there is a problem with the stove.
Old 01-16-13, 08:56 PM
Received 1,051 Votes on 975 Posts
Did you do the conversion yourself ?
If you did.....did you change the regulator setting ?
Your conversion kit came with a set of instructions....did you follow them to the letter ?
Many companies will no longer sell the conversion kits directly to the public due to issues like this.
Old 01-19-13, 02:57 PM
B
I had my furnace guy do the conversion. I do not like gas or electricity. He's not an appliance tech but a furnace/gas guy. he had the conversion directions and went over them a few times.
Old 01-20-13, 04:05 AM
GregH's Avatar
Super Moderator
Is your "furnace guy" a licensed/certified gas technician?
Most licensed gas techs will normally be familiar with gas appliances.
Did he connect a manometer to the gas supply to check that the pressure is what the manufacturer recommends?
