Getting Inside newer Frigidaire Dryer GLGQ 2152 ESO
Old 01-17-13, 07:07 PM
G
This one has the front panel. I need to replace the bearing cup. But cannot find how to raise the top of the cabinet. There do not seem to be just the putty knife spring clips.
Thanks, Gary
Old 01-17-13, 08:02 PM
G
Old 01-17-13, 10:03 PM
Received 1,030 Votes on 956 Posts
Did that dryer manual give you the needed info ?
Old 01-18-13, 01:48 AM
pugsl's Avatar
Received 71 Votes on 64 Posts
Your dryer has 2 screws in back top, Remove screws slid top back and take off, Remove control panel ( becareful usually panel is cracked and there screws from inside also holding panel on), Take 2 screws out of front panel from inside, Take panel off Remove drum, Usually you will not need to replace plastic socket or ball just need lube. If plastic part is worn out just replace that about 6 bucks. Be sure to lube socket good. #20 square drive works best on screws.
