How to stop Squeaky- Noise of Oven Door?
Old 02-18-13, 05:05 PM
PineCone's Avatar
Hi:
I have a Gas-stove(Natural Gas) with four burners on the top and working really good even though I purchased it more than 15-20 years ago from local Bray and Scarf(?).
The problem is that whenever open and close an oven door which takes place before and after cooking, there is squeaky-noise which sounds the oven-door is getting old and needs some lubrications to stop squeaky-noise.
Is it OK to use any common lubricant found in local hardware store?:
If I can, what sort of lubricant should I apply on both side doors(right and left) of the gas-stove oven?
Thanks for any help in advance.
Old 02-18-13, 06:19 PM
Received 1,049 Votes on 973 Posts
Sometimes it's at the hinge point where the metal plates are where the door slides on and sometimes it's the springs just inside the hinge area and, of course, out of site.
It's not critical what you use.
When I have to take care of that problem I'll remove the door and then take out the hinge plates. I carry a synthetic black grease that works real well.
