Gas Range Side Wall Clearance
Old 02-23-13, 07:24 PM
I am remodeling my kitchen and replacing all of my appliances. I have purchased (and received) a new 30" gas range to replace my old electric. The installation manual says that I need a min. 5" side wall clearance to a combustable material from the sides of my oven. Currently I only have a 30 1/2" opening, which I can make 36" without having to redo all my cabinets. Is there a way around the min. clearance? The manual says a "combustable material", so could you use a different material for the walls like metal, ac duct board, or other non-combustable material?
Old 02-24-13, 01:13 AM
Received 1,019 Votes on 946 Posts
I believe that figure refers to clearances above the burners. Most ranges can be slid in right next to a cabinet.
Can you leave a make and model number.....It can be checked out.
Old 02-24-13, 06:50 AM
KitchenAid 30" Slide-In Gas Range KGSS907SSS03. Thanks
Old 02-24-13, 07:17 AM
czizzi's Avatar
Received 14 Votes on 12 Posts
I take it that they require a minimum of 5" if you plan on placing an appliance garage near the range or have it butt up against a refrigerator side wall. Or any cabinet that sits on the countertop adjacent to the range.
Old 02-24-13, 11:05 PM
Zero clearance ranges they are not.
They do require 5" from a combustible surface. That requires a major modification to the cabinets.
I checked with an installer I know and he said that the unit does run hot and needs the air on the sides. He wouldn't comment on using a non flammable substance and less free air.
