Thermador UCV30AS/01 Downdraft Won't Raise
Old 02-27-13, 06:26 AM
Z
The relay board, 418319, checks out. The button board could be the problem. Any advice based on experience with this Cook N Vent downdraft?
Old 02-27-13, 08:26 AM
Received 1,027 Votes on 953 Posts
I have limited knowledge on this system.
Are the buttons lighting up or not ?
If they are not lighting up there could be a power supply failure on the main board or you could have a broken wire between the board and the button assembly.
Old 02-27-13, 08:31 AM
Z
Since the unit won't rise and all but the rise button are on the side, I can't tell if all buttons are lit. Having said that, I'm not sure any of the buttons ever lit.
There don't appear to be any broken wires.
Old 02-27-13, 08:45 AM
Do you have an actual schematic for that product ?
I don't but will try to locate one.
Since you have a moving mechanism.....the wire moves too. That was the reason I suggested a broken wire.....and it doesn't need to be visible. It could be one conductor in a multiple wire cable.
Old 02-27-13, 09:01 AM
Z
I do have a schematic PDF, but its 811kb and the site max is 50kb. I could e-mail it to you.
Old 02-27-13, 09:15 AM
Z
Here is a link to the parts list:
https://www.thermador-eshop.com/serv...d=UCV30AS%2f01
